gear box stuck
gear box stuck
Post by grumpy old man on Thu Jun 30, 2011 5:18 pm
My hi jet is stuck in top gear. Can anyone help ? Neutral
grumpy old man
Re: gear box stuck
Post by rich the mechanic on Thu Jun 30, 2011 9:06 pm
Hi does the gear stick move? there are two cables which control the box so depending on why it's stuck you may be able to fiddle the levers at the box end.
Re: gear box stuck
Post by grumpy old man on Fri Jul 01, 2011 9:52 am
Yes gearstick does move, I'll try that and see if I can free it. if not "I don't know"
grumpy old man
Re: gear box stuck
Post by difflock123 on Fri Jul 01, 2011 10:30 am
Most cable controls end up being dry (causing them to stick or jam).
if you can move the gearbox end, check the cable fittings at the gearstick and gearbox are OK.
and also spray some WD40 or similar down the cables. its not the best lubricant, but its an easy test.
what year and model hijet is it?
and where abouts are you?
Re: gear box stuck
Post by grumpy old man on Sun Jul 03, 2011 6:28 pm
Thanks for that, have had it looked at and it is gearbox thats at fault. My hijet is 1993 1000 CC
I am in Ockendon, Essex.
grumpy old man
Re: gear box stuck
Post by difflock123 on Sun Jul 03, 2011 6:45 pm
grumpy old man wrote:Thanks for that, have had it looked at and it is gearbox thats at fault. My hijet is 1993 1000 CC
I think theres a few members near you then Smile
depending on how mechanically minded you are, you might be able to strip the gearbox and find/solve the issue.
other than that, its a new gearbox thats needed....
Re: gear box stuck
Post by rich the mechanic on Tue Jul 05, 2011 8:53 pm
Hi I'm in Harlow and the most common failure on boxes is a spring but I'm a bike mechanic and haven't had a car box apart, There is a gearbox place on The Hainault business park (Fowler road) and one of my mums neighbours used to do box rebuilds last I heard he was free lancing so I will try and get a number for you.
Re: gear box stuck
Post by grumpy old man on Sat Feb 25, 2012 11:40 am
Did have it fixed but it's done the same again. Think we was ripped off though. Does anyone know someone in the Ockendon area who works on these and is reliable and fair? Don't want to end up scrapping it but if I cant get this fixed I'm going to have to.
grumpy old man
Re: gear box stuck
Post by rich the mechanic on Sat Feb 25, 2012 2:47 pm
Arrow service station in thornwood common near epping work on them nice guys and they have picked up a few to work on since womoco stopped being a main dealer.
Re: gear box stuck
Post by grumpy old man on Sat Feb 25, 2012 8:28 pm
Thanks, it is getting it there though, but may try.
grumpy old man
Re: gear box stuck
Post by rich the mechanic on Mon Feb 27, 2012 9:37 pm
grumpy old man wrote:Thanks, it is getting it there though, but may try.
They do have a transporter for pick ups but don't know how far they would travel or what they charge I know they will pick up from mine for free but I'm less than five miles away.
On the other hand I have a towing bar and me and my mate dragged ours back from Surrey.
Re: gear box stuck
Post by HighlyJetted on Mon Feb 27, 2012 10:34 pm
I'd be tempted to pick up a second hand gearbox for it and just change it over.
You can easily spend more cash on fixing them then a used one would burn you.
Gearbox swap is only a few hours labour, in and out in a day.
Re: gear box stuck
Post by grumpy old man on Tue Feb 28, 2012 8:08 pm
Thanks all, I'm going down the second hand gear box route. Will let you know how it goes.
grumpy old man
Re: gear box stuck
