tiger in the tank
tiger in the tank
Post by rich the mechanic on Sun Jul 10, 2011 10:52 pm
I spotted this across the runway at North Weald at a test and tune day
It was running about 15second times running a R1 motor and VW polo steel wheels on a reliant back axle and if you want it the bloke will take offers in excess of £2800. Cool
Re: tiger in the tank
Post by HighlyJetted on Sat Sep 03, 2011 11:02 pm
Very nice Rascal(?) spot Rich Smile Bet the croud loved it, and I bet the cars it beat hated it!!
See what you mean by the header sticking down, I have already been thinking of putting mine in upside down, then doing the exhaust up the back of the cab truck style (with a little flapper cover plate Laughing )
I'm not having a back axle like that, and i'm not shaft driving it either.
Its having a solid axle like a kart, with a chain drive. And the engine will be much further back.
But i'm very much open to ideas?
Post by difflock123 on Mon Sep 05, 2011 12:35 pm
why are you having a solid axle with chain drive?
if you rotated the engine sideways (like the R1 engine in the pics), you could then have a sprocket on the diff input flange.
that would allow you to play around with the gearing much more easily
Post by HighlyJetted on Mon Sep 05, 2011 1:22 pm
I think I might have to consolidate this into one thread before it gets messy....
This is what makes me think chain driven solid axle:-
If I spin the engine round it will be off centre - not the biggest issue though
I have to have a prop shaft - thus the engine needs to be further forwards
Two engines onto one prop shaft is an engineering complexity - unlike a twin engined pro-kart's simplicity
Diffs are expensive (especially LSD's) and heavy
Solid axles also act as an anti roll bar if you build a trailing swinging arm frame type affair
I can change sprockets all day to change my gearing
Weight
How could I put a sproket on a diff flange and still operate suspension while the engine is attached to the chassis - the chain length and allignment would move about. Putting the engine on the axle would make the unsprung weight crazy. Or am I not getting your idea?
Post by Logi on Mon Sep 05, 2011 1:51 pm
It'd have been better with a Fireblade engine with that paintjob Laughing
Post by HighlyJetted on Mon Sep 05, 2011 2:56 pm
This song should be on repeat in the cab on this (tonka toy) truck:-
Post by difflock123 on Tue Sep 06, 2011 9:45 am
well you could make a frame off the rear axle, and mount the engine to it (which would keep the unsprung weight down)
but I was thinking more along the lines of fitting a central location bar/strap to the axle, to connect it to the chassis.
the suspension could move up at both sides (one only), but you would still have some suspension (articulation) so speed bumps/potholes/etc wouldnt be too uncomfortable
but because the diff would never alter where it was located, the chain drive to the flange should be fine.
the location bar would also stop the rear end squatting during acceleration.
Post by 8bit-ash on Tue Sep 06, 2011 2:23 pm
That would have a whole lot more 'win' for me if it was subtly painted with something disguising the engine.
Post by HighlyJetted on Tue Sep 06, 2011 3:28 pm
Ash, I want a load of milk crates and the plastic milk bottles painted inside with white emmulsion on the back of mine when it get to santa pod one day - then it wheelies its way down the first 20 metres Twisted Evil
Post by 8bit-ash on Tue Sep 06, 2011 8:34 pm
Now that would be funny, Milkmans outfit on too so it looks like you took a wrong turn onto the strip.
Post by rich the mechanic on Tue Sep 06, 2011 9:35 pm
Hi HJ no it's a Carry.
