Do i need a new ........
Post by LSD on Tue Oct 25, 2011 8:27 pm
Door lock, my driver side still locks if i push the pin down(from the inside) but wont "pop" back up when i try to un-lock it from the outside!
Any help would be gr8.......
justin
LSD
Re: Do i need a new ........
Post by difflock123 on Wed Oct 26, 2011 9:49 am
spray a bit of WD40 into the lock and see if it starts working.....
if not take the door trim panel off and see whats not working....
Post by rich the mechanic on Wed Oct 26, 2011 7:34 pm
the door pin is on a seperate bit of wire to the lock and barrel there is a little alloy block with a grub screw in which can come loose if you have central locking it can do all sorts of funny things if it is not set in the right spot.
Post by LSD on Wed Oct 26, 2011 8:21 pm
Hmmmmm i woz going to pull the door pannel off and have a look today ,but my girl ran off with my tool(s) thanks guy's your info is going to help!
LSD
Post by HighlyJetted on Wed Oct 26, 2011 8:26 pm
difflock123 wrote:if not take the door trim panel off and see whats not working....
If you slam the door really hard the door card might just fall off for you.
Worst bit is getting the window winder off without breaking it. Maybe slam it again?!
The mechanism is so simple, i think it may have been inspired by an american.
Post by rich the mechanic on Wed Oct 26, 2011 9:18 pm
more than likely but if you remove the door pull handle and remove the screw holding the door release on, you can pull the door card back enough to get to the lock assembly I can't get the window winder off ours But judging by the sliding door ones being both broken I would not be suprised to find that it has been glued on Exclamation
Last edited by rich the mechanic on Wed Oct 26, 2011 9:19 pm; edited 1 time in total (Reason for editing : spelling and grammar)
Post by LSD on Fri Oct 28, 2011 8:29 pm
All of the above=one fixed door lock thanks guy's!
LSD
Post by rich the mechanic on Fri Oct 28, 2011 9:11 pm
your welcome. Did the noise you made slamming the door wake an American up? If not must try harder next time.
