993 EFI Brake pads
993 EFI Brake pads
Post by leopard_pagan on Mon Oct 31, 2011 1:44 pm
got a front set arriving this week as my vans brakes are well POO! will get the rears done next month..
any tips on changing the front set?
special tools needed?
assuming they are similar to bike brakes.. undo the holding pins (usually seized), drop old pads out,... some how move the calliper pot back in, slot new pads/pins in.. pump brake peddle to move calliper pots back out.....
Re: 993 EFI Brake pads
Post by HighlyJetted on Mon Oct 31, 2011 11:01 pm
From memory think you just have to undo 2 bolts on the back of the caliper and then it slides off leaving the pads in the outer casting bit.
Might want to get a G clamp or a good sized set of plumbers grips to push the caliper piston back too. Build it back up with some copper slip for ease next time.
I do one side at a time and press the pedal after each, make sure you don't over spill on the brake fluid while your pushing back the caliper - someone might have topped it up.
Post by leopard_pagan on Mon Oct 31, 2011 11:13 pm
i have a G clamp as its what i use on the bike callipers Very Happy
& yeah, i always grease up bolts i undo.. i have the red brake grease as well. will use that.
ta.. bet ya the bolts holding the pads in will be a bastard to undo! sods law!
Post by HighlyJetted on Mon Oct 31, 2011 11:20 pm
Sounds like your almost preying for problems Smile they'll be fine, just make sure you find something that fits well and gives you some leverage.
Post by leopard_pagan on Mon Oct 31, 2011 11:34 pm
with the recent spate of seized bolts.... + never had these brakes off since i have owned the van..... Exclamation
i think i'll wait till my bikes pipes are back/fitted/MOTed before i do this.. at least if a bolts buggered i can still get to work!
Post by HighlyJetted on Tue Nov 01, 2011 10:15 pm
I like your thinking. Amazing how sometimes having a backup plan ready can make the job go good in the first place
Post by leopard_pagan on Wed Nov 02, 2011 11:12 am
had a little look today as am off..
wheel off
can see the brake calliper easy enuf, sprayed it with brake cleaner & got the wire brush on around the pins/clips.
got the large pin clip out no issues
but the thinner pin clip closest to you i cant see how that comes out with out damaging it.
& none of the pins moved & look well rusted in!...
didnt go any further & put what id taken off back on.
Post by leopard_pagan on Mon Nov 07, 2011 12:10 pm
sooo.. these retainer wire clips...... how do i get the thin one out with out damaging/bending it?
Post by rich the mechanic on Mon Nov 07, 2011 7:50 pm
you don't remove and then drift or drill out the hole and refit using some little R-clips.
Post by leopard_pagan on Mon Nov 07, 2011 10:33 pm
hmmmm good idea batman... be a while before i get time off work to get the R clips.. wonder if my fave nuts n bolts shop has em...
