no heat coming from heater
Post by smurff1975 on Thu Jan 12, 2012 11:22 pm
hi everyone i have just brought a 993 hijet last week and have found i have no heat coming out of the heater all the fan speeds work ok but only cold air comes out im not loosing any coolant so i havnt got a clue
all help is appreciated a very cold smurff
smurff1975
Re: no heat coming from heater
Post by PFM on Fri Jan 13, 2012 6:26 pm
Hi, and welcome. You've strayed a bit far from Catford, haven't you?
The heater matrix could be blocked, or the heater valve seized. You've filled the cooling system as per the instructions? If you run the engine with the rubber bleed cap off, do you get coolant out?
