I Quite Fancy A Set Of These
Post by Logi on Sat Feb 04, 2012 9:37 pm
Re: I Quite Fancy A Set Of These
Post by rich the mechanic on Sat Feb 04, 2012 9:46 pm
Oh! Suit you sir. Oh!
Blue check
Alloy check
Machined check
Want some check
Cheap check
Cool
Post by Logi on Sat Feb 04, 2012 10:10 pm
Same price(ish) as replacement plastic ones, cant be bad Smile
Post by rich the mechanic on Sat Feb 04, 2012 10:22 pm
I like the fittings I will keep them in mind for later jobs.
Post by oldie on Sat Feb 04, 2012 10:29 pm
Can't grumble at that price, I like them. Nice find.
Post by 8bit-ash on Sun Feb 05, 2012 10:57 pm
i'd like some of them in black.
Post by HighlyJetted on Mon Feb 06, 2012 11:36 am
Bet they wont grip the splined shaft very well with just grub screws?!
Post by Logi on Mon Feb 06, 2012 12:26 pm
Pretty sure one of the centres is splined?
Post by rich the mechanic on Mon Feb 06, 2012 1:05 pm
HighlyJetted wrote:Bet they wont grip the splined shaft very well with just grub screws?!
You want to bet the spline is round with lots of spikes so the grub screw will bite between two quite nicely.
Post by HighlyJetted on Mon Feb 06, 2012 7:39 pm
Yeah for a week, then the tooth you were on will give up and then onto the next one, etc, etc
Maybe if you took a grinder to the splined shaft on the hijet and make a couple of flat bits it might work for more than a week?
Post by rich the mechanic on Mon Feb 06, 2012 8:00 pm
HighlyJetted wrote:Yeah for a week, then the tooth you were on will give up and then onto the next one, etc, etc
The ones in the sliding doors are fairly hard as I took a file to one to see how hard it was as I was thinking of drilling and tapping to take some ford ones.
i quite fancy,,,,
Post by bones 851 on Mon Feb 06, 2012 8:07 pm
go on logi, be the test pilot and treat yerself, then you can give us the "pimping green light" ,,,,, Very Happy oh who else enjoyed the back end slide with the lovely frosty roads , cant beat the rear wheel drive for a bit of winter fun eh?...... affraid
bones 851
Post by Logi on Mon Feb 06, 2012 8:11 pm
bones 851 wrote:go on logi, be the test pilot and treat yerself, then you can give us the "pimping green light" ,,,,, Very Happy oh who else enjoyed the back end slide with the lovely frosty roads , cant beat the rear wheel drive for a bit of winter fun eh?...... affraid
Maybe Wink
Theres a splined centre in the kit.
Post by HighlyJetted on Mon Feb 06, 2012 11:45 pm
Do you think its the right spline count?
