Could someone do me a measuring favour...
Post by 8bit-ash on Sat Feb 11, 2012 9:01 am
Hi all,
I need to know the distance from the floor to the wheel arch lip/door bottom on the front. And the length of a front spring when fitted on a van. So from the top spring cup to the bottom spring cup. Ideally a 1999 to 2003 ish van.
Tape measures at the ready, go.
Re: Could someone do me a measuring favour...
Post by oldie on Sat Feb 11, 2012 11:11 am
Distance from floor to the top of the arch on the door is......625mm
Distance from floor to the bottom edge of the front of the door....330mm
From the bottom of the spring cup to the top of the spring cup.....185mm-195mm....top of spring cup is stepped.
Taken from a 2004 Piaggio Porter van.
Sizes taken from the pasenger side.
Post by 8bit-ash on Sat Feb 11, 2012 1:46 pm
Blooming brilliant thanks.
