rear door rattle
rear door rattle
Post by waz on Tue Feb 14, 2012 7:08 pm
Hi, my back door (on the van for you lot with a dirty mind) rattles like mad. Would it just be the case of adjusting the catch?
Waz
Re: rear door rattle
Post by PFM on Tue Feb 14, 2012 8:01 pm
It would, though the screws on the hasp on the body can be hard to shift. Stuffing an old towel between the tailgate and the frame can help too.
Post by rich the mechanic on Tue Feb 14, 2012 8:02 pm
Should be but might be worth slamming it hard as ours wil rattle like mad if we just shut it but give it a good shove and it shuts nice and tight.
Post by waz on Tue Feb 14, 2012 8:59 pm
rich the mechanic wrote:Should be but might be worth slamming it hard as ours wil rattle like mad if we just shut it but give it a good shove and it shuts nice and tight.
Even if I slam it, it still rattle's. When it is closed there is a little play in the door. Mite try the towel trick first.
Waz
Post by rich the mechanic on Tue Feb 14, 2012 9:21 pm
What is the door seal like if that is knackered then it maybe worth looking for a replacement.
Post by waz on Tue Feb 14, 2012 9:47 pm
Hi Rich, door seals are in good condition. The body could do with some work on it but there is no rust problems and mechanically very good.
Waz
Post by rich the mechanic on Tue Feb 14, 2012 10:20 pm
Then it is time to try and adjust tbe catch then although I did try to adjust one of the front doors only to find the catches are not adjustable.
Post by waz on Tue Feb 14, 2012 10:26 pm
I have had a quick look and I think the bit on the body can be moved.
Waz
Post by HighlyJetted on Tue Feb 14, 2012 10:46 pm
My old mpv used to do this, so I would smack the loop on the body with a lump hammer then it would shut up for a couple of months.
Post by bushwhacker on Thu Feb 16, 2012 4:54 pm
That's interesting. I accidentally backed into a pillar which stopped the rear door rattling for a while but it has since started again.
(The Hijet was otherwise unscathed but the pillar got marked).
