rear wiper testing help
Post by pww on Tue Feb 21, 2012 4:50 pm
Hi fellow jetters. The rear wiper on my 1.3 van doesn't work but I am not sure how to identify the problem. I removed the interior panel and disconnected the wiring connector block to the motor then put a multimeter across the two terminals in the supply wire. When I use the dashboard switch, i.e. turn it on, I get continuity at the terminal block in the door so I am assuming that the wiring is intact. I don't know what other testing I can do to establish if the wiper motor is dead. Any help would be appreciated as I am out of my comfort zone with auto-electrics.
pww
brainwave
Post by pww on Tue Feb 21, 2012 9:49 pm
Just thought of another simple test. Connect one of the numberplate bulbs to the rear wiper supply, switch on rear wiper, if it lights up then the wiper motor must be getting power.............simple.........I think.
Anyway I will post the outcome just in case it comes in handy for someone else.
pww
Re: rear wiper testing help
Post by waz on Tue Feb 21, 2012 9:55 pm
My rear wiper has stopped working and I noticed today that my number plate lights are not working either, must investigate further.
Waz
