I have a fuse box question i need answering..
Post by WeymouthGuy on Wed Feb 22, 2012 6:14 pm
Hi all, im new on here so hoping to get my question answered..
I had to do a small job on my Hijet 2001 model.. I took the terminal off battery for a short while
and when i went to tighten back up the battery terminals everything is dead, ive tested the battery and thats fine
and showing correctly on the meter, i have checked fuses near the front dash.. there is no ignition nothing, everything seems
totally dead as a door nail.. Now for my question to anyone in the know..
Does the hijet have 2 fuse boxes or just one, im abit in the dark why this has happened and why i dont have any
electric in the van now.. thought i would check on here incase someone can enlighten me?
Hope to hear from anyone that can point me in right direction..
I would be most grateful..
James
from Weymouth
WeymouthGuy
Re: I have a fuse box question i need answering..
Post by www.hijetparts.co.uk on Wed Feb 22, 2012 6:25 pm
Have you checked the earth strap from the battery to body is getting a connection?
http://www.hijetparts.co.uk
fuse box question reply
Post by WeymouthGuy on Wed Feb 22, 2012 6:27 pm
no i havent but i will now you have sugested it..
WeymouthGuy
reply
Post by WeymouthGuy on Wed Feb 22, 2012 6:31 pm
checked the earth strap and thats fine on the meter so its not that....
WeymouthGuy
Post by www.hijetparts.co.uk on Wed Feb 22, 2012 6:31 pm
turn the key to position 2 so that ignition lights should be on , then shake the lead from side to side,if the lights come on it should just be a matter of cleaning the connection to the body. hope you get sorted!
Sean
reply
Post by WeymouthGuy on Wed Feb 22, 2012 6:33 pm
hI sean
i have tried that and still nothing.. do u know if there is 2 fuse boxes?
WeymouthGuy
Post by www.hijetparts.co.uk on Wed Feb 22, 2012 6:41 pm
Just the one fuse box, there are a few manuals available to download from this site which have wiring diagrams which may some help though.
reply
Post by WeymouthGuy on Wed Feb 22, 2012 6:43 pm
I have been told that there is a fuse under the air filter on drivers side, does anyone else know if this is right?
WeymouthGuy
Post by www.hijetparts.co.uk on Wed Feb 22, 2012 6:58 pm
there are a few fuses and relays along the loom, depending on the engine type/size they will be in different positions. if you want to give me a call on 07835598059 i can send you the relevant diagrams if theyre any use!
Post by 8bit-ash on Wed Feb 22, 2012 7:25 pm
What job were you doing?
reply
Post by WeymouthGuy on Wed Feb 22, 2012 7:27 pm
i was installing one of my ham radios in the van just undone the battery and took off the terminal and then put it back on..
WeymouthGuy
