window seal
window seal
Post by EvaInNorfolk on Tue Mar 13, 2012 8:15 pm
I'll swap this https://www.youtube.com/watch?v=eW_1NEMcYIY&feature=related for information about where I can get a seal for the bottom of the window on a door. Mines broken off a bit so I've covered the hole in tape to stop water getting in and making rust!! Not an ideal long-term solution.
EvaInNorfolk
Re: window seal
Post by rich the mechanic on Tue Mar 13, 2012 8:41 pm
Drivers or passengers? I have a box with loads of bits on I think I have a seal strip but will have to have a look failing that measure it for lenth and get one from anything that is the right lenth or longer my Escort needed some and I just found some longer ones and trimmed them down to fit.
Re: window seal
Post by EvaInNorfolk on Tue Mar 13, 2012 8:46 pm
Driver's side door.
Can you buy it "on a roll", so to speak? Is this a case of going to Halfords or similar?
EvaInNorfolk
Re: window seal
Post by rich the mechanic on Tue Mar 13, 2012 9:03 pm
No it is metal coated with rubber if you do make some don't worry to much about a good seal they are onlyu there to deflect the majority of the wet stuff there are drain holes at the bottom of the door for the water to run out.
Re: window seal
