electric avenue!!!!!!
Post by bones 851 on Tue Apr 10, 2012 2:28 pm
here we go again, just returned from a great wee trip to skye, van ran like a treat, all 220 miles no probs, went out this am to paper shop, started, came out of paper shop, dead, nout, nothing, no ignition no noise, sod all, , removed relay from under dash board, flicker ignition lights on?????, placed back in nothing . usual wiggle of wires, flash of lights again, dam, this bloddy van and electrics , bucketing down will go under dash board again and look for ? needle in hay stack, shit looks like another trip to auto spark much expense, starting to think it must like it there, ..... dam dam dam....... Mad Twisted Evil
bones 851
Re: electric avenue!!!!!!
Post by PFM on Tue Apr 10, 2012 5:22 pm
Ignition switch, or wires to it? (soldered connections)
Post by bones 851 on Tue Apr 10, 2012 6:46 pm
i think its the wires to the switch, had a look under dash, its like a snakes den, dont think its much, however, i know nothing of electrics,,,,, confused
bones 851
Post by HighlyJetted on Mon Apr 16, 2012 11:33 pm
Check the wire in the boot that goes to the battery, the thin pair. Give them a pull, see if they break off.
Post by HighlyJetted on Tue Apr 17, 2012 12:13 am
You have the same sort of issue as this http://hijet.findtalk.biz/t740-please-help-13-efi-is-dead
and as your light came on when you pissed with the main relay, its down there somewhere maybe.
If you tap it with a screwdriver does it make the ecu light flicker on?
They are really prone to fail on honda's - not that that helps at all Laughing
You can actually bypass that relay if you shove a wire in the right place. Its just a big switch after all.
There is a wire that comes of the igintion switch, which activates the main relay, and it also kicks in the fuel pump relay once the ecu is powered up.
But if the main relay doesn't turn on the ECU, then the fuel pump one won't kick in either as the ecu lets the fuel pump relay activate.
Post by HighlyJetted on Tue Apr 17, 2012 12:36 am
Here's a diagram - i've simplified the one from the "1.3 efi porter diagram - electrical"
See if you can get your head round it.
Post by bones 851 on Tue Apr 17, 2012 1:41 pm
cheers hj, myself and eletrics just dont mix, however, have passed on advice to mate alan (sparkie) phoned an hour ago, stated van now going, corroded wires in dash leading to ecu, also loose wiring underneath near side of van, causing draining, when earthing due to movement, alan said this can happen again due to loom being exposed to elements and being so low, given agood rubber covering and i think ill re underseal the van at the weekend, alan was surprised it didnt happen on the way to= or return trip from skye!!!!, said if any thing happens again to contact yourself as your knowledge gave him a head start, so thank you very very much......., if you pass up this way , ill treat you to a very large scotch indeed..... Very Happy
bones 851
Post by HighlyJetted on Tue Apr 17, 2012 7:51 pm
Very happy to help, and even happier you are now rolling once again.
