Occasional poor starter
Page 1 of 2 1, 2  Next
Post by Steviel81 on Tue Jun 12, 2012 9:47 pm
Van - 1997 - 1000cc
Occasionally it struggles to start. Problems started day after we got it home, it had a good hour drive the night before, then the next morning it wouldn't fire, put a new battery on, still wouldn't go, played about with the HT leads, it fired, it's ran fine for 4 weeks now, then tonight the missus rings me (I work away during the week) that it wouldn't start. I got her to wiggle and press in the HT leads, nothing?
Got her charging up the start pack incase the battery is a bit low so she can try again tomorrow with that on it.
Is there any common starting faults on these?
Cheers
Stevie
Steviel81
Re: Occasional poor starter
Post by rich the mechanic on Tue Jun 12, 2012 10:15 pm
I know of no common probs but when you say struggles to start are we talking slow turn over or just doesn't want to fire but spins ok till the battery gets run down?
Post by Steviel81 on Tue Jun 12, 2012 10:19 pm
It turns over fine, but doesn't fire.
Steviel81
Post by 8bit-ash on Tue Jun 12, 2012 10:37 pm
How old are the plugs? Worth changing. Mine was a poor starter till I changed them.
Post by Steviel81 on Tue Jun 12, 2012 10:43 pm
Could be
Might do a proper service on it, where's best to get new leads, cap and rotor arm from? Can get plugs easy enough.
(Sorry for the noob questions)
Steviel81
Post by rich the mechanic on Tue Jun 12, 2012 10:55 pm
When we bought ours it wouldn't start when we went to pick it up but it had been seen started and running and it was the plugs and that is all I have changed as far as the ignition system goes my personal opinion is unless cracked or other wise broken don't replace unless you have money to throw away just change the plugs and try it, it is them 99% of the time.
Post by Steviel81 on Tue Jun 12, 2012 10:58 pm
Will give the plugs a change and go from there Smile
Bit of a habit wanting to change things from playing with MR2's Smile
Steviel81
Post by HighlyJetted on Tue Jun 12, 2012 11:15 pm
Dunno, I see rotor arms and dizzy caps as consumables along with the plugs. For it to run its best keeping those service components in good condition helps and they tend to be small change on the grand scale of things.
What sort of MR2? Have I soft spot for them myself
Post by Steviel81 on Tue Jun 12, 2012 11:20 pm
One of these
Mk2 Rev1 turbo with a few cheeky bits on it
Steviel81
Post by rich the mechanic on Thu Jun 14, 2012 10:09 pm
HighlyJetted wrote:Dunno, I see rotor arms and dizzy caps as consumables along with the plugs. For it to run its best keeping those service components in good condition helps
I ran my escort for three years with no physical contact between the coil electrode in the dizzy cap to the rotor arm it was only when I was given a box of spares with one in I realised that it was broken.
Post by Steviel81 on Tue Jun 26, 2012 4:51 pm
Swapped out plug 3 (Rear most) and it fired! Now to try swap out the other two when it's not raining and my bum crack not being a drain for rain water!
Any tips on what to use to get the front two out? Its a bit tight from engine - body?
Steviel81
Post by Little Black Van on Tue Jun 26, 2012 7:41 pm
I remember using a universal joint extension on a T bar to get them out, and on a couple I found it easier to get at them from underneath, despite the mud shield.
Little Black Van
Post by Steviel81 on Sat Jun 30, 2012 4:26 pm
Little Black Van wrote:I remember using a universal joint extension on a T bar to get them out, and on a couple I found it easier to get at them from underneath, despite the mud shield.
Went and bought one, then looked in my tool box and one was in there Embarassed
Fitted them all, van starts and runs so much better than it has since we got it! Smile
Steviel81
Post by Steviel81 on Fri Jul 13, 2012 8:32 pm
Once again this little thing has let me down! Won't start again! Going to swap out all the ignition, try find this cooling problem and probably sell up (after I convince the missus to sell it)! Never had a car this unreliable before!
Steviel81
Post by Logi on Fri Jul 13, 2012 9:54 pm
Its one thing i've noticed with Hijets, a good one is great, but a bad one is a pain in the arse Mad
Post by HighlyJetted on Fri Jul 13, 2012 11:44 pm
Logi wrote:Its one thing i've noticed with Hijets, a good one is great, but a bad one is a pain in the arse Mad
Bang on the money right there! 100%
My silver one was faultless except it was dissolving slowly. This new white one it bang tidy too.
Ernie the pickup is a dog, messed with and un-fixed by joey boys.
I think half of them die because they take them for a service where they change the coolant, and they don't know what they are playing with - like at quick fit or a local garage etc.
But back to your van, what's it doing? Does it cough and pop like it could possible start? Does the engine light come on as normal?
Have you check your wire of death in the boot battery tray?
Post by Steviel81 on Sat Jul 14, 2012 6:46 pm
It turns over, occasionally it tries to cough like its going to start but doesn't. I'm getting a spark, but not sure if it's good enough to get it to start, it's getting fuel too.
I've ordered new leads, dizzy and igniter so going to swap them over and see how that goes.
With the over heating issue, I've got an old rad cap I'm going to drill a hole in a do what you suggested in another thread HJ.
The annoying thing is I got an early finish yesterday so wanted to shoot home early, but I had to sit about for hours waiting on the missus coming to get me!
Steviel81
Post by Steviel81 on Mon Aug 27, 2012 4:38 pm
Right got it all running now, no idea why it didn't start?
Got it pressure tested, found a small leak, re-bled it properly, runs fine, went away camping in it (about an 80 min drive) it filled the over flow tank twice getting there, drove it back and it only filled it once?
I HATE THIS VAN!
Steviel81
Post by HighlyJetted on Mon Aug 27, 2012 7:37 pm
Steviel81 wrote:I HATE THIS VAN!
Not surprised! Bet its getting to the "royally pissing you off" stage.
Sticking thermostat - have you changed that yet?
Does the electric fan kick in properly if you let it sit there idling?
Post by Logi on Mon Aug 27, 2012 7:48 pm
Steviel81 wrote:Right got it all running now, no idea why it didn't start?
Got it pressure tested, found a small leak, re-bled it properly, runs fine, went away camping in it (about an 80 min drive) it filled the over flow tank twice getting there, drove it back and it only filled it once? !
It's getting better then.... Wink
Post by Steviel81 on Tue Aug 28, 2012 11:54 am
Haha Logi Smile
HJ - The fan is on a switch, it does get hot when you're sat on idle though
Steviel81
Post by HighlyJetted on Tue Aug 28, 2012 4:56 pm
Well a block test would save you the wasted effort of a head gasket job if its not the fault!
My Ernie the pick-up over heated before I stripped it down. And on ripping the engine apart the head gasket had not failed anywhere, nor were there any cracks in the cylinder head or block.
There has obviously been a fair amount of water loss though as the seat/bonnets are covered in brown scum residue. Someone had put a new water pump on it, and a new thermostat. And they obviously knew it was overheating thus why they were getting rid of it.
Many of the pipe clips on mine are fucked, thus I'm replacing them all as I go. The big hoses and the little ones too.
I haven't had my radiator off yet to inspect that. And my electric fan didn't kick in on its own when up to temp.
Between this hijet community, we should be able to work out the exact weakness or cause of the Hijet overheating syndrome.
Post by bushwhacker on Tue Aug 28, 2012 6:09 pm
HighlyJetted wrote:......
There has obviously been a fair amount of water loss though as the seat/bonnets are covered in brown scum residue. Someone had put a new water pump on it, and a new thermostat. And they obviously knew it was overheating thus why they were getting rid of it. .........
The water loss may not mean much. When the fan belt snapped on mine it decided to pump water everywhere. Problem solved when fan belt replaced and water topped up.
Post by Logi on Tue Aug 28, 2012 7:13 pm
The trouble with Hijets is usually down to penny pinching owners, they are hugely expensive to fix, and poor pattern/2nd hand spares availability compounded by quite a low sale value means many have had " quick fixes" in. the past. Add to that a propensity for overheating and difficulty bleeding the system and its not surprising so many members have probs.( usually thats just before the member has bought it.... )
Me. Id flush the rad & system as its likely had some sealant in the past. New caps, bleed it properly, I still hold by filling it and opening the bottom cap and letting it piss out as the force removes any airlock, ok you make a mess, but its full Smile
Post by HighlyJetted on Wed Aug 29, 2012 12:03 pm
The fan belt runs the water pump so the moment that's missing tension etc you're pending the boil. I've put the sportrak's water pump and pulley on my new engine, they are a bit different and the pulley is smaller so it should pump faster/harder, good thing or bad I don't know!
On stripping the hijet pickup's engine down I found alot of silt/radweld in the block, it all collects around the liner of the piston closest the gearbox. It had really baked rock solid, I has to smash it up with a screwdriver to get it out.
Someone had changed the radiator cap under the passenger seat to one that was completely wrong fit, the rubber sprung bit was about 8mm too big making it sit all wrong literally allowing water to spew out. I've also had to seriously repair/modify the thermostat housing as it had some fine hairline cracks through it, so I have internally sleeved it with some tight fitting stainless steel tubing, with lots of epoxy.
If I run it for the first time and it boils up I won't be all that impressed bounce
Post by HighlyJetted on Wed Aug 29, 2012 3:33 pm
I've just taken more of the pickup apart...
The bottom radiator hose clip has broken in half, and the bottom of the radiator is leaking.
Plus behind the radiator there is the heater control valve, one of the clips on that is leaking too.
Rats nest!!!
Post by waz on Wed Aug 29, 2012 5:13 pm
Funny that you say that Logi. I IMHO had a great one took me to Hungary and back and did not miss a beat. The main reason I sold it was reading all the tales of woe on this forum and me not having the skills to fix it or the money to pay a garage to fix it I sold it before anything did go wrong.
Waz
Post by Steviel81 on Wed Aug 29, 2012 5:18 pm
I wish I had a garage and time to strip it down over and rebuild it, but I don't have a garage, and to rent one would probably cost the same as paying someone to do it for me as I'd only be able to work on it every second weekend, then it would take up all my free time Sad
In other news, the MR2 passed MOT first time Smile
Steviel81
Post by Steviel81 on Thu Sep 13, 2012 5:50 pm
Took it to Indigo GT (very reputable Evo specialist) who are just round the corner from my missus' house and work, they agree that with the symptoms it's having, it's more than likely its the HG that's gone.
They're going to change the HG and then go from there.
It will be for sale when fixed, only reason we're fixing it is it'll be easier to sell as a working camper than a fucked one!
Steviel81
Post by Logi on Thu Sep 13, 2012 5:59 pm
But, if it's fixed why sell? You've had the grief, might as well see what the fun's like? Very Happy
