lights trouble
lights trouble
Post by hiasajet on Mon Jul 09, 2012 9:23 pm
Anyone know why my sidelights are on all the time even with light switch off and my brake lights dont work when ignition is on, but when ignition is off side lights work with switch and so do brake lights? Have cleaned battery earth but that hasnt worked. Thank you
hiasajet
Re: lights trouble
Post by rich the mechanic on Mon Jul 09, 2012 9:27 pm
Sounds like a trace it back from the lights till you find the break in the loom as it is shorting across somewhere.
Re: lights trouble
Post by HighlyJetted on Mon Jul 09, 2012 10:01 pm
What engine version is yours? 1.3 or 1.0, carb or efi?
If you tell me which yours is I'll look at the wiring diagram and give you some possible leads.
Re: lights trouble
Post by hiasajet on Mon Jul 09, 2012 10:10 pm
13oo efi, 2001
hiasajet
Re: lights trouble
Post by hiasajet on Mon Jul 09, 2012 10:11 pm
thank you to both of you
hiasajet
Re: lights trouble
