Wheel bearing
Wheel bearing
Post by pintor528 on Wed Aug 22, 2012 7:49 pm
Hi all, new to the forum lots of good info and suggestions. I own one of this little vans and having problems with front wheel bearing its a 1994 hijet with s85lv-znrk stamped on id plate, it has drum brakes on the front and having problems locating bearing as all i find are for disk brakes can any one point me in the right direction pls.
pintor528
Re: Wheel bearing
Post by PFM on Thu Aug 23, 2012 8:10 am
Hi, and welcome to the site.
Just had a quick look at the Japarts website and they seem to agree you should have disc brakes! There were a few things that Daihatsu chopped and changed around that time. You might have to have a word with a dealer (suggest Womoco if you're in the UK)
Re: Wheel bearing
Post by pintor528 on Thu Aug 23, 2012 11:08 am
Thanks for suggestion, i am in Gibraltar and dealer here not much help, guess i will have to take it apart and look for Nos on the actual bearings.
pintor528
Re: Wheel bearing
Post by PFM on Thu Aug 23, 2012 11:44 am
That could explain why you have a different spec. If you get numbers off the old bearings you should be able to obtain replacements from a bearing supplier, much cheaper than the dealer or a parts supplier.
Re: Wheel bearing
Post by HighlyJetted on Thu Aug 23, 2012 5:26 pm
PFM wrote:If you get numbers off the old bearings you should be able to obtain replacements from a bearing supplier, much cheaper than the dealer or a parts supplier.
That's what I'd do!
Parts databases are a bit hit and miss. Computer says Nooooo Rolling Eyes
Re: Wheel bearing
Post by PFM on Thu Aug 23, 2012 6:32 pm
Dug a little further. Mick's Garage lists front shoes for 1986-1989 Hijets (QH NO. BS 872) but no wheel bearings for that age range. It's not impossible that this set-up was continued in some markets later than in the UK, so if those shoes are the same as yours, you know what period your front hubs date from.
Is yours carb or EFI?
Re: Wheel bearing
Post by pintor528 on Fri Aug 24, 2012 1:23 pm
Thanks for the info, some details of van carb, points, no servo, 4 gears, 1000cc,
chassis no jda00s85v00067541. Very confusing as they seem to have used front end from earlier model.
pintor528
Re: Wheel bearing
