Hijet Engine Problem
Post by peanut_brittle on Wed Aug 29, 2012 8:27 pm
I bought a hijet with a 993 engine from a lady in Devon, sold as seen but recently MOT'd. Drove it up the road back to Scotland but it died just outside Hamilton, yellow light which looked like a fan came on then an oil light, then tonnes of smoke out from under the passenger seat.
RAC man told me I needed a new engine (when he stopped laughing:-) I can get my hands on a 1300 engine but need to know if it will be a straight swap for the other engine or is it hugely different? Really want to get the girl running again, a real fixer upper but lovely. Can anyone help? Thanks
peanut_brittle
Re: Hijet Engine Problem
Post by Steviel81 on Wed Aug 29, 2012 8:43 pm
That's a fair ol drive and to break down so close to home is bad Sad
I can't answer your question, but welcome to the forum.
I did drive from Wales to Greenock (My home town) and break down at Langbank, at 2am on a Saturday morning, just as it started snowing! Sad
Steviel81
Post by HighlyJetted on Wed Aug 29, 2012 8:50 pm
bad times mate, Although if it wasn't knocking or rattling you'll be able to fix that engine. Sound like head gasket has gone, and there will be a few other little fauts that caused it to fail probably.
But as a guide to go from the 993 to the 1300, you will need.... Engine, gearbox, ecu, full wiring, all the sensors, maybe the dash clocks, and possibly a load more stuff!
Thanks for the info
Post by peanut_brittle on Wed Aug 29, 2012 9:44 pm
Thanks for sending the info. I might get her to a mechanic then and see if she is repairable first. You've given me hope!
peanut_brittle
Groan!
Post by peanut_brittle on Wed Aug 29, 2012 9:46 pm
Bummer! Glad to know someone else is of the same mind as me and likes the journey! Intend to tour Scotland if I can get her fixed.
peanut_brittle
Post by rich the mechanic on Thu Aug 30, 2012 9:00 pm
HighlyJetted wrote: maybe the dash clocks, and possibly a load more stuff!
The only difference between the clocks is the 1300 has a petrol light which the 993 doesn't but we have a 1300 clock set in our 993.
Post by Logi on Thu Aug 30, 2012 9:28 pm
Welcome from a fellow Scots Hijet owner
Nae luck wi the van, hope you get it sorted
