Spark Plugs
Spark Plugs
Post by Whitetruckman on Sun Sep 02, 2012 1:40 pm
Hi,
I want to replace the spark plugs in my Hijet pick-up 1.3 4 cylinder petrol engine......
Don't laugh,,, I have had both seats up and removed the inspection panel from the floor of the truck body,,,, and I can't see where the plugs are?!
I can't see any distributor cap or HT leads to follow. Am I stupid of what? ( you can answer that ).
If you can describe what to do or show me a diagram I'll be your friend for life.
Whitetruckman
Re: Spark Plugs
Post by HighlyJetted on Sun Sep 02, 2012 1:48 pm
I'll refrain from answering the second question, but for your first question:-
Look under the passenger seat, there you can the rocker/cam cover on the top of the engine....
Word on the street says one of them is a right bitch to do Wink
Re: Spark Plugs
Post by waz on Sun Sep 02, 2012 5:25 pm
Takes longer to take the covers of than replace the plugs. If I remember right number 3 from the front a bit awkward because of the seat support bar. You will need a long spark plug tool
Waz
Re: Spark Plugs
Post by Whitetruckman on Mon Sep 03, 2012 2:12 pm
Thanks HJ and Waz for your help.
It's a nice day to get my head under the passenger's seat.
Whitetruckman
Re: Spark Plugs
Post by HighlyJetted on Mon Sep 03, 2012 2:41 pm
Sure is! I'm waiting on the call from the MOT station for my white hijet van.....
Re: Spark Plugs
Post by Whitetruckman on Mon Sep 03, 2012 9:39 pm
Dunnit.
Thanks for your advice and diagrams guys.
That was a learning curve. Apparently, each spark plug is capped with its own transformer which is supplied with low tension voltage eliminating the need for HT spark leads. Very cleaver ! I have never seen anything like that before.
Squirted WD 40 on the retaining nuts and left it for an hour or two. They then came off easily.
Job done.
Hope your van passed the MOT HJ.
Whitetruckman
Re: Spark Plugs
Post by HighlyJetted on Mon Sep 03, 2012 10:22 pm
Oh wow yours is a multi coil one, sometimes know as "coil over plug" and other terms.
And yeah I am now MOT legal again Smile
Re: Spark Plugs
Post by PFM on Tue Sep 04, 2012 7:37 am
No wonder he couldn't find the plugs to start with!
Re: Spark Plugs
