leaky distributor housing
Post by the little yellow van on Sun Sep 30, 2012 10:54 pm
hello again does anyone know where i can get a new distributor housing as mine has a slight crack in it which leaks oil
Re: leaky distributor housing
Post by HighlyJetted on Mon Oct 01, 2012 8:56 am
You'll have to help us out a little here!
What year/age is it - and what engine spec do you have?
Does the HT leads on the dizzy come off straight, or are they at 90 degrees?
Post by the little yellow van on Mon Oct 01, 2012 2:17 pm
Hahahahaha sorry yeah that would be helpful it's CB42 (S85) 993cc and the HT leads come off at 90 and im looking for the distributor to cam coupling housing
Post by HighlyJetted on Mon Oct 01, 2012 2:36 pm
I can't help you there, but either try:-
Steve in Derbyshire 07774621664
Dave in Dewsbury 07527171704
or maybe try Emma & Jerry in Bath on either 07804 798774 & 07734 604021
Post by Little Black Van on Tue Oct 02, 2012 10:45 am
Interesting, CB42 but the HT leads come off at 90 degrees? Has it got an ECU? If so, it would seem the CB41 dizzy cap is compatible.
Little Black Van
Post by HighlyJetted on Tue Oct 02, 2012 12:17 pm
Cb41 should have a diaphragm operated advance and retard on the side.
Post by the little yellow van on Tue Oct 02, 2012 4:48 pm
ok sorry i might have confused this slightly the boots at the dizzy end of the HT leads are set at 90 degrees not the dizzy
Post by Little Black Van on Tue Oct 02, 2012 7:06 pm
Ah, and there was me getting my hopes up... Razz
Little Black Van
Post by ianhart on Mon Apr 14, 2014 11:23 pm
dIZZY LEAKING WILL JUST BE THE O-RING ON THE HOUSING I KNOW AS I HAVE JUST DNE A HEAD GASKET IT COMES WITH THE KIT.OTHERWISE REMOVE THE 4 10MM BOLTS IN THE DIZY HOUSING TO CYLINDER HEAD WAK A NEW O-RING ON THE HOUSIN WITH A TOUCH OF SILYCOON AND REMEMBER TO GET IT TIMED UP TO NO 1 AT TDC
ianhart
